Ethan3.14159
A mildly interesting comparison between my 840 EVO and 850 EVO
I get the feeling that it was bottlenecked by the onboard RAID for the motherboard. I would love to test that setup again with a proper controller.
Great scores Shane!
Something is really wrong with your setup, the Intel 750 should be getting 2GB/s easily.
That is much better. It could be due to a number of reasons, the first that comes to mind is that is shares PCI-E lanes with the GPU so it's possible that you are simply maxing out on available PCI-E lanes.Ok it appears I had the wrong driver. Here is with right driver.
Still not 2GB read. Is there something else i can do?
Makes sense, and good to know. Looks like these NVMe drives will need to use the 5GB tests. Jason, want to update this to the OP?OK I found out why it's not reporting true speeds after posting in the Intel forum.
"Due to limited support for large queue depths and multiple workers, the full performance of NVMe SSDs could not be seen in Crystal Disk Mark 3.0.4 . For example, the maximum read bandwidth on this build for one NVMe drive was ~ 1.5 GB/s and the maximum IOPs was ~ 150K IOPs."
I have to use Crystal Disk 5.02
Leaderboard updated!Jason is slacking here!![]()
