pc stops playing videos
cdawg14
hello I have a custom pc with specs as follows
amd fx8120 eight-core cpu
GeForce gtx 970 gpu
sabertooth 990fx mobo
vengeance 12 gb 3300mhz ram
900 watt 80+ silver psu
windows 10 pro
ntx switch 810 case
the cpu is liquid cooled with a h100 cooler
now my issue
my computer is slow and doesn't perform like it used too takes longer to load up web pages and switch applications and every time I watch a video online via youtube,facebook or any website my pc goes to either a black screen or it says (AN ERROR HAS ACCURED PLEASE TRY AGAIN LATER) and then the website refreshes and plays but after it refreshes and if I move my mouse the video freezes until I stop moving the mouse here is a youtube video of my issue
things I tried
downloaded ddu and did a clean install of my gpu drivers
reinstalled windows
did a hdd test and no errors where found
ran mem test and no errors
my cpu stays at around 32-37 c
so I am now asking for help please and thanx
Run the following programs so we can see whats going on and we'll go from there.
1.
Please download AdwCleaner by Xplode onto your Desktop.
•Please close all open programs and internet browsers.
•Double click on adwcleaner.exe to run the tool.
•Click on Scan.
•After the scan you will need to click on clean for it to delete the adware.
•Your computer will be rebooted automatically. A text file will open after the restart.
•Please post the content of that logfile in your reply.
•You can find the logfile at C:\AdwCleaner[Sn].txt as well - n is the order number.
2.
Please download Junkware Removal Tool to your desktop.
•Shutdown your antivirus to avoid any conflicts.
•Very important that you run the tool in this manner:
Right-mouse click JRT.exe and select Run as administrator
Do NOT just double-click it.
•The tool will open and start scanning your system.
•Please be patient as this can take a while to complete.
•On completion, a log (JRT.txt) is saved to your desktop and will automatically open.
•Post the contents of JRT.txt in your next message.
3.
Please download Malwarebytes' Anti-Malware and save it to your desktop.
  • then click Finish.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
Please post the log that Malwarebytes displays on your screen.
4.
Download OTL to your Desktop
•Double click on the icon to run it. Make sure all other windows are closed and to let it run uninterrupted.
•Click on Minimal Output at the top
•Click the Quick Scan button. Do not change any settings unless otherwise told to do so. The scan wont take long.
◦When the scan completes, it will open two notepad windows. OTL.Txt and Extras.Txt. These are saved in the same location as OTL. Just post the OTL.txt file in your reply.
then post the logs from the following 4 programs.
1. Adwcleaner
2. Junkware removal tool
3. Malwarebytes
4. OTL
1.
•Click on Scan.
2.
3.
EXPLORER.EXE
IEXPLORE.EXE
USERINIT.EXE
WINLOGON.EXE
4.
1. Adwcleaner
3. Malwarebytes
4. OTL
here r the files u asked for although adwcleaner did not find anything
Doesn't seem like you are infected at all. I would suggest downloading and running a temp file cleaner such TFC or Ccleaner and then post back results after cleaning.
TFC - http://www.bleepingcomputer.com/download/tfc/dl/92/
Ccleaner - http://www.bleepingcomputer.com/download/ccleaner/dl/189/
I have downloaded both programs and I started to watch some facebook/youtube videos and thought it was fixed but then the issue came back videos either went black and still had sound or they say an error has happened and restarts the web page and begins to freeze
I just now received an error that said
"display driver has stopped responding and has recovered"
this is really getting annoying there has to be some sort of fix
I would again, try to uinstall display driver with DisplayDriverUninstaller in safe mode completely clean it up. Then download and install (checking the clean install option) the latest drivers. Also make sure you have the latest chipset drivers, motherboard bios and other updates for Windows. Ensure your BIOS settings are correct.
