The VCR King
Well-Known Member
My case has these clip things that go on both sides of a hard drive then it allows the drive to slide into a drive bay. I've been looking on Amazon for them but I don't know what they are called...
Thank you!
I actually found them. Theyre called hard drive rails. There are multiple brands of them and they all look the same and will likely work with my case.Just use screws.
I have found a crap ton of them on Amazon, but mostly Dell and IBM. I can NOT, for the life of me, find any Coolermaster ones that will for sure work with my case.I read your OP wrong. Yes, they're rails.
