Tuffie
I have connected two additional routers to my existing router to expand the wireless network for added coverage:
I have cabled from router > switch > patch panel ports for each of 2 routers that have disabled DHCP and set static IP addresses for them
I have set static IP's set for any devices connecting to them..
Some devices trying to connect to the new WiFi networks sometimes will work fine and others will not.. For example the PS4 works consistently all the time on one of the new WiFi AP's how phones and laptops are 50/50 getting 'limited connection'.. It seems like it might be devices that are moving between the different networks that have issues. Not sure what to do, any ideas?
