So my gpu has started running hotter than before in the last couple of months, dusting only helped a negligible amount since it was never that dirty to begin with. It is an EVGA gtx 660, I went ahead and applied ceramique 2, right away the first time I tested it I noticed it was hotter than before under load, idle temps were just as good though (32-35c). Running GTA 5 it hit 99c and I turned it off, when stress testing with furmark the temps jump up to 60c almost immediately and continue to increase from there after. I tried applying the paste in four different ways, and always made sure the surfaces were very clean (used rubbing alcohol). First way I applied it I used a pea sized dot (seemed to be too much and spilled over a little), second time was a very small amount spread thin and evenly (this was by far the worst of the four), third time was a medium dot, and the current way is a small dot. The second way where I spread it thin and evenly I tested with furmark and the temps hit 90c in seconds, that was startling, the other three ways seemed to have yielded the same results, but it is running about 10c hotter on average under load compared to what it was before I applied the paste myself. I know the paste might have a set time, and that might help by a few degrees, but it isn't going to make up for the 10c, and definitely not going to go back to stock temps. So my question is, has anyone else experienced this? And what paste should I be using? I have never put new paste on a gpu, ceramique 2 was all I had, apparently it doesn't work well on a gpu.
I'd like to add I reformatted two days ago, clean install windows 10. My tower does have a side fan but it is outdated (from 2007), but this still isn't right, I've had the gpu for two years and these high temps seem to be a more recent thing. Any help would be appreciated, thanks in advance.
