The VCR King Well-Known Member Nov 26, 2015 #1 I can't find a way to let my VMWare VM access my PC's FusionHDTV7 tuner card. Is there a way to link this device to the VM? Thanks
beers Moderator Staff member Nov 26, 2015 #2 Direct io but it's probably not a supported device. Also you would lose it on the host if you dedicated it to the vm
The VCR King Well-Known Member Nov 26, 2015 #3 beers said: Direct io but it's probably not a supported device. Also you would lose it on the host if you dedicated it to the vm Click to expand... Oh, I can't allow host and VM to access at the same time? Nevermind then... :/
