Budget?
GTX 960 or R9 270
Quad core cpu
8gb of ram.
Here is a link to pc partpicker.
http://pcpartpicker.com/p/s98rNG
Everything you need except for keyboard, mouse, monitor.
I thought it would be too expensive for me too buy right now. I was just planning to play games like Evolve, Battlefront, and Dayz for now which don't require a very good computer. I know that a really good computer costs around $1,100, and that's too expensive for me to buy.If you are going to be playing more demanding games then why buy something that you'll have to upgrade later on, you'll be wasting money. Get what you need now and you'll be set. If you want to play better games then you'll have to get a new video card and higher wattage power supply.
I don't mind getting a computer that doesn't perform as well as the computer you just mentioned. I mean I really didn't want to spend much on a computer even if the computer you just mentioned is only $886. I'm not sure though; I'll think about it. Thank you for your help. You are the best.Not true. This is a decent computer for the price under $1000
http://pcpartpicker.com/p/p8smwP
Will play most games at high settings.
