Opinions on a Budget Gaming PC
Stephan Karidis
Hey guys I want to build a gaming PC for about 700 British Pounds (about 1030$) and I've chosen the following components but I just want more opinions to make sure that they are as good as I think and that they are compatible of course! Here are the components I've chosen so far:
Intel Core i5-4590 3.30 GHz Haswell Socket LGA1150 Processor
GeForce GTX960 DirectCU2 OC Strix 4096MB GDDR5 PCI-Express Graphics Card
Z97-D3H Intel Z97 (Socket 1150) DDR3 ATX Motherboard
Blitz 1.1 Original 8GB (2x4GB) DDR3 PC3-17000C9 2133MHz Dual Channel Memory Kit (AVD3U2133090)
Caviar Blue 1TB SATA 6Gb/s 64MB Cache HDD - OEM (WD10EZEX)
QBX Mini-ITX Cube Chassis - Black
Cooler Master Hyper 212 Evo CPU Cooler
Builder Series CX 600W V2 '80 Plus Bronze' Power Supply (CP-9020048-UK)
What do you think? I've heard that the GTX960 might be a bit too much since I'm mostly going to be playing MOBAs, and that a 450w PSU might be enough and that I might not need a 600w one. All of these components can be found on Overclockers.co.uk by the way. (I already have an operating system by the way.)
Thanks in advance!
For £700 this is a nice build. The 200R is like £50 so that will be a good case to get. For £50 it is one the best cases you can get. The other good case for about £50 is the Zalman Z11 which is good if you like LED lighting. The Corsair is more discrete but if you like lights the Zalman is a good option. For £60 or so you can get an NZXT Phantom 240 which is also a very, very good case for the money. If you remove the case how much do you have left to spend?
I'd recommend the CX600M - the M is the modular one. Really helps with cable management because you can remove cables you don't need.
I think you should look at the latest generation i5s too. i5 6xxx CPU, Z170 board and DDR4 RAM (but check the board - some Z170 boards use DDR3, others DDR4. The CPU can work with either DDR3 or DDR4). Do you plan to overclock? You've got that CPU cooler. If yes, you need to get a 4690K or a 6600K. The 4690K will be a lot cheaper but it is last generation and doesn't support DDR4 RAM.
I would go for LGA1151
Here is my pick for m-itx OC PC, I pick a case with similar style as I can't find it at pcpartpicker list...
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (£189.99 @ Dabs)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£24.99 @ Amazon UK)
Motherboard: Gigabyte GA-Z170N-WIFI Mini ITX LGA1151 Motherboard (£104.99 @ Amazon UK)
Memory: Corsair Vengeance LPX 8GB (2 x 4GB) DDR4-2400 Memory (£42.56 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£55.71 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£37.98 @ Amazon UK)
Video Card: Asus GeForce GTX 960 2GB Video Card (£149.99 @ CCL Computers)
Case: BitFenix Phenom Midnight Black Mini ITX Tower Case (£55.90 @ CCL Computers)
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply (£63.85 @ CCL Computers)
Total: £725.96
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-01-03 15:29 GMT+0000
Cheaper m-atx non OC alternative
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor (£155.00 @ Amazon UK)
Motherboard: Gigabyte GA-B150M-D3H Micro ATX LGA1151 Motherboard (£68.40 @ CCL Computers)
Case: Aerocool DS Cube Black Edition Silent Cube MicroATX Mini Tower Case (£58.58 @ CCL Computers)
Wireless Network Adapter: TP-Link Archer T4U 802.11a/b/g/n/ac USB 3.0 Wi-Fi Adapter (£17.99 @ Amazon UK)
Total: £650.06
Generated by PCPartPicker 2016-01-03 15:53 GMT+0000
