Going from laserjet to inkjet is the stupidest idea ever.
The reason is that I don't need to print so often, and when I have to print, mostly I print color.
I have a Brother laser printer and really can't smell a bad odor.
The problem with using an inkjet printer is that if you don't print often enough, the ink will dry up and may clog the print head causing you to take it in have it cleaned or possibly buy a new printer every year. A monochrome laser printer is very cheap on toner replacements. I've had my printer now for about 3 years and went through the original toner that came with the printer and 1 high yield cartridge. I've been getting the low toner message for months now but it still prints. I have another one here when it completely quits printing. I can usually get the high yield toner for less than $40.
Now the color laser printers are much more expensive to keep up. You have to replace each color toner as it needs it and each one could cost up to $75. If I was in a better financial state then I would have a color laser myself. I also have a color inkjet only because I need color for my business cards. My other inkjet went out last year so needed a cheap replacement. I always print to the laser cause I never need color except for my cards.
If you get the inkjet, just make sure you print color and black every couple weeks to keep the ink flowing.
I did read and this is what I replied with.
Some lasers may omit more odor then others.
If you're in a very populated city, the small emissions from the occasional laser printer shouldn't be your primary concern when it comes to clean air.Thank you. So now , I know ALL lasers would emit ozone, which is not good for breathe, I am now researching for inkjet.
To others, I am not living in US. I am living in a highly populated city. My home is very small. The smell of Ozone is unacceptable.
LOL I don't know what businesses you've been in but I have never seen this.Most printer rooms now are separated and have quite extensive exhaust systems.
LOL! Yeah, alright then. "Printer rooms"? Nearly every single office and educational institution I've seen have laser printers in offices and common areas, not dedicated printer rooms. Even copier rooms don't have "extensive exhaust systems".Most printer rooms now are separated and have quite extensive exhaust systems.
