Do the specs work together?
Yoav Zimet
Do they work effeciently?
Is this a good gaming pc?
is there any changes i should make?
Regards
Here Are The Specs:
Processor - Quad Core i5 4460 3.2Ghz S1150
Motherboard - Gigabyte GA-Z170X-Gaming 3 S1151
Ram- 8G Kingston Hyper-X Fury DDR3 1866Mhz CL10
Graffics Card - Gigabyte GTX970 4GB WindForce3 OC 1114Mhz 4G DDR5
SSD * - SSD Samsung 650 120GB SATA III
HardDisk - Seagate 1T 3.5'' Sata3 Barracuda 3 Years Warranty
Optic Disc Reader - LG DVD-RW X24 GH24SCO
Case - Zalman Z11 PLUS NEO
Power Supply - FSP Raider 650W 80+ Silver 5 Years Warranty
Fan For CPU - Zalman Performa CNPS5X
Case Fans – Corsair Air AF120 Quiet High Airflow 120mm (X3)
Software- Windows 10 64 bit Hebrew OEM
Wifi Card- TP-Link USB TL-WN722N 150Mbps
Parts are compatible but some points:
- i5-4460 + overclocking motherboard makes no sense
- GTX970 has only 3.5GB memory, does not support asynchronous shaders and is expensive considering 14/16nm GPU's are around corner. Recommend Radeon R9 instead, for example R9 380
- I recommend at least 250GB SSD
- Consider PCI Express WLAN card
The i5-4460 is a socket 1150 CPU, while that motherboard is a socket 1151 motherboard. If you want to stay with 1151, I'd recommend the i5-6600K.
You need DDR4 with that motherboard.
If you want an SSD, get a Samsung 850 EVO. 120GB is also incredibly small, I'd get at least a 250GB.
I'd get a more reputable power supply, from Corsair, EVGA, Silverstone, or Thermaltake.
If you need WiFi, get a PCI-E dual-band card.
Non overclock get i5 6500, ditch CPU heatsink
overclocker get i5 6600K
RAM to be DDR4
SSD to 250GB
wifi card a bit slow. Would suggest you get dual band or home plug.
