salvijus02
Soo simply if my pc only needs like 200w and I have like 750w power supply soo will my power will just drain to nothing all those like 500w would just go nowhere and I just pay more for my bill?
WHAT IF I UPGRADE MY PC FROM TIME TO TIME?It will only use as much as it needs. It also will not run as efficiently as it could (power wise) with that large a PSU. If you only need 200W or so I'd go with a 450W PSU.
AND IT DOESNT AFFECT MY PC IF I BUY JUST A POWER SUPPLY WITH MORE WATTS IT DOESNT AFFECT MY PC RIGHT?It will only use as much as it needs. It also will not run as efficiently as it could (power wise) with that large a PSU. If you only need 200W or so I'd go with a 450W PSU.
Depends on what you plan on upgrading. Unless you're running a gaming video card you'll never need more than 400W.WHAT IF I UPGRADE MY PC FROM TIME TO TIME?
No but it's a waste to drop money on a PSU you don't need.AND IT DOESNT AFFECT MY PC IF I BUY JUST A POWER SUPPLY WITH MORE WATTS IT DOESNT AFFECT MY PC RIGHT?
I just need to know If it doesnt matter how much watts is there.voyagerfan99if post: 1992610 said:Depends on what you plan on upgrading. Unless you're running a gaming video card you'll never need more than 400W.
In your current situation it doesn't.I just need to know If it doesnt matter how much watts is there.
Did you read anything I said?I just need to know If it doesnt matter how much watts is there.
ThanksIn your current situation it doesn't.
ThanksDid you read anything I said?
Thanks buddy.RANDOM YELLING
If your PSU can't provide enough wattage then your PC won't function. If you can provide more than enough wattage to the system then that's great, but it won't automatically increase your power consumption.
Whats wrong?WHAAAAAT?
Whats wrong?
