First Gaming Pc Build
Adrian27
I have decided to give building my own computer a go after seeing many others attempting to build their own. I just want to be able to play current games (DayZ, Rust, H1Z1, CS:GO) on high quality. All advice and recommendations are appreciated.
Looks pretty decent, although that wifi adapter is pretty low end.
Any chance on a M.2 SSD instead of that 850?
What is the difference between a low and high end adapter?
Is there enough of a difference in transfer speed to reason the M.2 SSD?
I have an Intel AC adapter and a Gigabyte one.. both were $30 ish and provide 867 Mbps on AC wireless.. I'd recommend either of these PCI add in adapters!
A pci-e M.2 SSD is capable of much higher..like 5x higer speed (2200/900).. provided it isnt a Sata3 interface.. in which case you might as well stay on a typical 2.5" drive (550/500)
