Loosing internet connection in my laptop.
Dennis<3
Hi. Internet in my computer just stops working after 30min-1h of using it. It shows that it is connected, but internet won't work untill I restart the computer. Hope for quick replies ;)
Wireless or ethernet cable? How many pc's attached to the network? Do you have the latest driver installed for the network card you are using?
make sure you have the latest wifi adapter drivers and also might want to reset (unplug for a minute than plug back in) your router.
2 pcs are atached to the network and I'll try updating the drivers and let you know if it works.
