My games crash on my PC every 10-15 minutes?
IShotLightning
Hello I'm new here!
My PC crashes every 10-15 minutes during game play I don't know why. My game runs max setting 60 fps temps stay at 50%
Here are my specs
OS Windows 10
Hard Drive 1 TB
Ram 8 GB Corsair brand xms 3 I think and 650 MHz
Graphics Card GTX 650 1 GB
Power supply 450 watt kentek brand
Processor Intel core i5 3330 3.0 GHz
This was a dell insprion 660 I upgrade the graphics card and the power supply
Temperatures are not measured in percentages... What are they in degrees?
Is the whole thing just shutting down or does it give you an error? What game(s)? Has it always done this or did this just start happening?
I've been playing black ops 2 it gives no error it just crashes just go to desktop.
How to check degress?
Use RealTemp to measure CPU temperature: https://www.techpowerup.com/realtemp/
Use GPU-Z to measure GPU temperatures (it's on the Sensors tab): https://www.techpowerup.com/gpuz/ or you could use GPUTemp: http://www.gputemp.com/
Measure CPU and GPU temperatures whilst playing a game or when either/or is at load.
Sounds like heat could be the issue.
You can download HWMonitor.
http://www.cpuid.com/softwares/hwmonitor.html
Have that running while you play the game and see what your max temperatures get to.
HWmonitor not good enough for you? :P
