Hi, I'm building a computer to host a minecraft server, and my budget is $100-$130. The server will aim to have about 10-20 players and since the budget is so low, I have decided to get a motherboard with onboard processors and Intel graphics. Please be mindful when choosing that the factors are:
Which one gives the most "bang" for your buck?
Which one is the fastest?
Which one is easiest to use
Here are the choices:
1.
MakerBrightTM Raspberry Pi 3 Model B Select Kit w/Raspberry Pi 3, Clear Case, 5.25V 2.4A PSU, 8GB NOOBS MicroSD, 6' HDMI 1.4 Cable - OEM
2. ASRock Q1900B-ITX Intel Celeron J1900 2.0GHz Mini ITX Motherboard/CPU/VGA Combo
3.
ASRock D1800B-ITX Intel Celeron J1800 2.41 GHz Mini ITX Motherboard/CPU/VGA Combo
4.
ASRock Q1900-ITX Intel Celeron J1900 Motherboard/CPU/VGA Combo
Thanks!
1.
3.
4.
Thanks!
