How much would this old desktop be worth?
SuperFuzz
Hey folks, I have an old desktop from 2007. It has Windows Vista (64 bit), 8GB RAM and three harddrives. One harddrive has a capacity of 500GB; and the other two have a capacity of 900GB each. The processor is an Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83 GHz 2.83Ghz.
It does not have a Wifi card/chip, but I think this can be added easily? Anyway I was just wondering if it would be worth anything as it is taking up a lot of room, so if I can sell it that's a bonus. If not, do you think I could easily upgrade the computer to add more RAM, a better graphics card and a wifi chip/card?
Thanks for your help.
Is it built from parts or an OEM/Manufactured one?
You can get a wireless USB or PCIE NIC which are pretty cheap, a lot of dual band ones are even around ~$20.
Heya, I think it is built from parts because I got it from a custom build company. I forgot to add that the graphics card is NVIDIA GeFORCE 9400 GT (2500MB approx memory).
The motherboard is an ASUS P5Q SE.
Yeah, thats pretty old now, DDR2 ram, Have you considered just using it as a backup machine, for pics, media, I dont know if you have kids? might be a good machine for children to play on?
Selling that, maybe $100 to someone who really needs a PC, but with vista and relative inexpensiveness of modern machines, you'll be hard pressed to get much more.
Do you reckon the computer could be upgraded enough to work as a decent video gaming machine? I guess the graphics card I have isn't good. The minimum specs I would need to upgrade to would be:
  • Windows® XP Service Pack 3 or better
  • Intel® Core 2 Duo 2.0 GHz, Core i3 OR AMD Athlon 64 X2, or better
  • 2 GB RAM
  • NVIDIA® GeForce® 7800, ATI X1800, Intel HD 3000, or better (256 MB of video RAM and shader model 3.0 or better)
  • 35 GB available HDD space
  • Broadband Internet connection
  • 2 GB RAM
Just not worth it anymore, in my honest opinion. Others may feel different but its old tech and you'd be purposely buying old, in some cases nearly-obsolete parts.
To clarify, I'm not saying its not doable, I'm saying its really not worth spending the $$
You already have better then the minimum specs you posted except for maybe the video card.
The motherboard has windows 7 drivers on Asus website so you should have no problems putting windows 10 on it. I would keep it and get a better video card.
