Well, guess what happened this morning?
johnb35
Administrator
I would also check to make sure that none of the tabs from I/O shield are actually inside the usb slots, I've seen this happen before. Also check your front usb ports for any contacts touching each other or possible damage.
spirit
Moderator
Along with power loss to USB I also get no display and I lose sound too
Yeah something is shorting. Could be that your I/O shield is not installed correctly as John has said above, checking USB ports for bent pins etc is a good idea. Try temporarily unplugging your front panel USB ports from the board too.
The VCR King
Well-Known Member
So for real me and the previous owner have spend nearly $500 in repairs and it's a short? I'm seriously pissed off right now. When I get home I'll rebuild it. :mad:
spirit
Moderator
Nearly $500 in repairs? You bought a new PSU for like $50 and a CPU cooler and some more RAM... not $500 worth of parts?
As I said, I think your old PSU was bad anyway and anyway you have a decent one now.
Please don't be angry, these things happen. :( There is a resolution though and we'll find the problem. :)
The VCR King
Well-Known Member
Seriously man thank you so much for giving me a clearer answer. I already know that there are no bent pins on my USB ports but I do know I bent like three pins in my memory card reader from when I inserted a CF card the wrong direction but the pins aren't actually touching so that shouldn't be the issue...
spirit
Moderator
No worries. I'd still disconnect the card reader anyway, just to make sure.
The VCR King
Well-Known Member
Remember I spent $300 on all new RAM and Windows when I first got the machine and the previous owner did the same things too. And I am still pissed because I know I wasted money on some of the parts but I do like my new PSU and cooler because both are better. The cooler was needed anyways because I needed to access the RAM slots plus the new COOLER is cooler.
spirit
Moderator
Well to be honest you probably didn't buy the RAM or the CPU cooler to sort these issues out. You probably bought the RAM to improve performance and the CPU cooler to either keep the CPU cooler or to enable you to overclock, so I wouldn't be too annoyed about that. And hey, who cares what the previous owner bought? His money, not yours. ;)
You bought the PSU to stop these shut downs and weird happenings and I think it was worthwhile. It just looks like there is something, possibly a standoff, the I/O shield or a USB port, which is causing occasional shorts.
The VCR King
Well-Known Member
The RAM was replaced when I bought the machine because I was told it was infected or something... And I added more to increase performance and the cooler was replaced because the other one blocked off my other RAM slots. Again man thank you so much for helping narrow down that it is indeed a short happening somewhere. Seriously I can't thank you enough.
spirit
Moderator
No worries mate, let's see if we can find out what's wrong once for all eh? ;)
When you get time (like a whole day free) it would be a good idea to completely rebuild the whole system, checking for any possible shorts. My guess is that it's your I/O shield or a USB port. If it was a standoff I think you might get a short if you knocked the PC slightly.
johnb35
Administrator
Ram can't get infected. Ram is either good or bad but can't get infected because as soon as you shut system down all data from memory is pushed back to hdd. Not sure who told you that.
The VCR King
Well-Known Member
I think it actually might be the IO shield because I've noticed it looks like it's kinda crooked and not quite right
The microcenter technician ... And now I know that was total B/S but back then I didn't know a lot about that type of stuff so I just went with it LOL
spirit
Moderator
In that case you'll need to take your board out and then reinstall the I/O shield. It's possible it has come loose or one of the pins on it is touching the board.
The VCR King
Well-Known Member
Honestly that's what I think is going on because the IO shield is angled a bit and it's not lining up right if you look closely.
spirit
Moderator
Try sorting that out first then. Whilst you have the board out to reinstall the I/O shield look for other possible shorts too and count and tighten the brass standoffs as well. Get back to us once you've done this.
The VCR King
Well-Known Member
Post an image of it.
Here:
Due to time I probably won't be able to get to it until this weekend and I'm also buying an anti-static wristband so I don't do what I did last time and kill a GPU with a static shock. Can you also tell me what a standoff looks like and how many there should be?
Plus while I have the PC open this gives me a chance to further improve cable management. :D
spirit
Moderator
The number there should be depends on your board and your case. You need to count how many holes there are for them on your board and then see if they're installed in the right places on your case. Only put them where there are holes on your board, you don't want standoffs on your case touching the board where they shouldn't be.
You may need to use some pliers to loosen and tighten them.
They look like this:
Btw I can see in the photo the top right of your I/O shield doesn't look quite straight. It may just need pushing in a little bit.
