How to store thermal paste?
The VCR King
Well-Known Member
I still have nearly the entire syringe of thermal paste left from when I got my Zalman installed. I have it back in it's package with the cap on it but I was wondering if there's any other precautions to take when storing thermal paste, because I'd like to preserve it for use in building future rigs in the upcoming years. :)
Darren
Moderator
I had a tube of normal Arctic Silver 5 that lasted me 2-3 years of several uses. Just put the cap on it and you're fine.
The VCR King
Well-Known Member
Doesn't matter. As long as it stays capped it won't dry out.
Ok. Just making sure I was doing it right. Thanks!
Exactly!
That's why I laugh at people that put globs of paste on and burn through tubes way too fast
The guy at MicroCenter used a very small amount. My tube is still pretty much full. The old paste that was scraped off the CPU was such a small amount it was like paper thin.
Too much thermal paste acts as an insulator too.
I never knew that. I actually used to think more = better but appearantly not. LOL!
Darren
Moderator
You basically want enough to provide a thing coating across the entire top of the processor. Just a little bit in the middle and the pressure and heat will even it out as needed. The majority of the heat comes from the center of the chip so it's not 100% critical to get it all the way to the corners.
The VCR King
Well-Known Member
I had MicroCenter use the paste that came with my cooler, Zalman brand, and my PC never goes above 25C under load and it idles around 19-20C.
Darren
Moderator
Considering 25oC is 77 Fahrenheit, and hardly above room temperature. I really really doubt that... My Phenom II idled above 30oC usually.
spirit
Moderator
I just apply a small pea-sized blob of paste directly in the centre of the CPU and then install the cooler. A tube of thermal paste should last you a long time. You should only use a small amount each time. Too much and it won't help to keep your temperatures down.
The VCR King
Well-Known Member
My office never goes above 60 degrees. Any more and I feel hot, LOL. In the winter time our furnace failed and the temp in the room was like 40 and my PC said 15C.
Laquer Head
Well-Known Member
Great Video..
SpriteMidr
And remember to take the cap off first ;)
In all fairness, I have a syringe that is probably 5 or 6 years old nearly knocking about still, I didn't think they did degrade over time :3
