lincsman
Hi there. I am running an AMD fx-6300 processor and when set to "performance" in BIOS it runs at 3.8GHZ. I tried manually overclocking and it was different than it was years ago and it didn't work (computer told me on boot screen and sent me into BIOS). However I did manage to set the bus speed to 215mhz with everything else on auto, but CPU-Z tells me that the max clock speed with that setting is 3.77GHZ. So it is safe to figure that the more I up the FSB speed, the lower the clock speed will be. So, my question is, what is the best setting to get the best frame rates in games? If a higher FSB speed is better how high should I set it? I would rather ask first as apposed to further trial and error. Thanks.
