Why doesn't my burned CD work in my car?
Status
Not open for further replies.
Okay so what's the problem? Why doesn't it just work when I drag it there? Why isn't it that simple like it should be?
"Drag items here to create a burn list".... and then click burn....
Why isn't it as simple as that?
Did you burn it as an audio CD or as a data CD with a bunch of mp3s?
Oh I see what you're saying.... there's an option on the menu... I changed it.... should work now...
Replace layer 8.
Yea that's why my Ubiquiti Access Point is up and running..... good thing I didn't have to call in the "experts"
SAME fruity PROBLEM!!!
I CLICKED BURN AUDIO CD AND STILL DOESN'T WORK!!!
THIS IS NOT ME... THIS IS THE STUPIDITY OF THE SOFTWARE....
IT SHOULD BE AS SIMPLE AS CLICK "BURN" AND IT BURNS....
johnb35
Administrator
Windows media player does work. Is your music listed in your library? Open media player, go into your library, add songs to the burnlist, burn cd. Does the music cd play in computer ok? Are you sure they are MP3's or WMA's? Car stereos usually won't play any other format.
beers
Moderator
Doesn't your stock radio support USB? Just throw some files on a flash drive man, this isn't 1999.
Cool. I'm glad you were able to get a single AP going after weeks and having to roll through buying various waves of equipment.
spirit
Moderator
SAME fantastic PROBLEM!!!
Firstly please watch your language.
Secondly make sure Windows Media Player is set to burn an Audio CD and not an MP3 CD. It might be trying to make an MP3 CD when your stereo only supports Audio CDs. It sounds to me like it was making an MP3 CD.
Have you tried...
- a different CD?
- a different burner?
- a different stereo?
- different software?
If not try all of those.
The stock radio in my $28,000 Lexus? No, they don't have USB adapters for this unfortunately. And getting a radio from Best Buy would make the car look like garbage....
I foresee the same problem when I buy my Lamborghini.
Have you tried...
- a different CD?
I have tried all kinds of CD's... it's not the CD's problem... they are DVD-R's....
I only have one burner on this computer...
I only have one stereo in my car...
spirit
Moderator
OK so it is burning an Audio CD.
I don't know what you mean by 'they are DVD-Rs'. Surely you mean CD-Rs?
And what I meant was can you try the CDs in another stereo, not necessarily in a car - any stereo. That's just to check that your CDs can be played in another stereo to see if your car stereo is the problem. Can you try burning a disc and then playing it on your computer? Do you have a friend who can try to burn a disc for you?
With your car being from 2014 can't you put music on an SD card or a USB flash drive instead of a CD? It would be a lot less hassle! Most modern car stereos can do this.
Laquer Head
Well-Known Member
Really?!...Really?!...... *warp back to reality*
Laquer Head
Well-Known Member
Not sure how specifying price adds to the conversation. My under 20k mazda3 supports doing that out of the box and even has other crap like integrated Pandora.
You could alternatively stream over Bluetooth from your phone. Just trying to give you some solutions.
Exactly!!
$28K Lexus from Bobs House of Clunkers! LMAO
Status
