Need help deciding between 2 laptops
Ps the screen on the asus is not very impressive. If it had a better resolution or at least better quality, id be all for it....but then the graphics card is better so it would also be better for autocad, photoshop, dreamweaver...hmmmm
You do realize both of those are only dual core processors with 4 threads, they are not quad cores. I would look around more for definitely 1080 resolution.
Yes I know they are both dual core. Is quad core really a necessity?
And Isnt the Dell 1080 resolution?
Yea, it's not bad for the price. If you can't get the free shipping to work, just contact them about it. I'm sure they can fix it for you.
