Origin Saint
Well-Known Member
Hi all,
Recently gave my i5-4690K with a single, stock-fanned CM Hyper 212 EVO a small OC. Managed to get a 4.2 GHz OC @ 1.2 V. I have tested using Prime 95 26.6 on small FFT (4 threads) for about 2 hours. The temps never rose above 76 C, averaged about 74.5 C. Also ran AIDA64 stability test for about 2 hours and didn't crash, or ever go higher than 76C, averaged around 71 C.
Aside from all of that before the OC, I was at about 50 C idling (the room is about 21 - 26 C ambient).
The possibility exists that I applied the thermal paste less than professionally, and that could be causing something.
Is there anything wrong with my results here? I'd like to know if it would be worthwhile to try and re-seat it with some fresh paste.
Thanks for the help in advance!
 I'm not sure that the difference in fan type would do anything noticeable to the temps or not.
