Moving; trying to decide which computer to keep
HEDoubleRAMStix
I am moving residences this summer and was wondering which older Dell computer I should keep? Both are old Core 2 Quads that would be basically an HTPC for watching movies on.
I have:
Dell Optiplex 780 Mini tower (BTX design)
Core 2 Quad Q9550 2.83 GHz
6GB DDR3
AMD Radeon HD 6570 2GB
Dell Studio 540 Mini Tower
Core 2 Quad Q9650 3.0 GHz
10GB DDR2
500W aftermarket PSU
Nvidia Geforce GTX 950
I have an i7 4790K machine I built myself a year ago, but I use it strictly for gaming. Plus its noisy (7 case fans plus GTX 970).
i would say keep the studio 540 much better video card, more ram, a little faster cpu.
The reason you would have 7 case fans, in my opinion, are to run them all at 30-50% speed, thus still keeping the machine quiet.
You can spend a lot of money making a noiseless PC, but you don't have to spend a lot, if anything, to make a quiet PC. Just configure your fans.
I ended up keeping the 780. I switched the Q9650 that was in the Studio and put it in the Optiplex. Also the Geforce GTX 950 is overkill for a Core 2 based system (and more power hungry than a GTX 745).
I really like the Optiplex designs for 2006 to 2009 (The GX520 to 780). They feel indestructible like a tank. Plus, the DDR3 SDRAM is upgradable all the way to 16GB.
I'm going to keep the GTX 950 in storage until I build an AMD Zen computer around the holidays.
I have:
6GB DDR3
10GB DDR2
That doesn't really make any sense to me, but whatever you think man.
I'd put the slower card in storage, at idle there really isn't a difference in power consumption. If you're really that worried about 30 watts (and about 5x more performance) then unscrew one of your lightbulbs while playing to compensate.
