Should I buy a pc?
Yovel
So a few days ago I asked if I should buy a pc and was convinced to buy one at a price around 1500$, so here it is, should I buy it? Is it worth it?
Price - 1615$
CPU - intel core i7 6700k 4ghz 8Mb cache s 1151
CPU cooler - corsair hydro h60 high performance liquid CPU cooler
Motherboard - Asus H110M-A LGA1151, intel H110, DDR4, PCI-E, VGA, DVI, HDMI
Ram - 2x Kingston ValueRAM iGB DDR4 2133Mhz CL15
Video card - MSI GTX 1070 ARMOR 8gb OC 8GB GDDR5 DVI HDMI 3xDP PCI-E
Hard disk - Western Digital Caviar Blue WD10EZEX 1TB Sata III
SSD - transcend SSD370 TS128GSSD370 128GB SSD SATA III
Power supply - corsair 500W active PFC 80+ CMPSU-500CXV2 PSU
Case - antec GX505 window Black Steel Case No PSU
Every opinion matter.
Thank you so much in advance!
It might be worth going with Z170 instead for unlocked multiplier. Otherwise you might be able to save a couple dollars with a non-k 6700
I'll look at that
You can fit way better stuff for $1600 than what you spec'd.
http://pcpartpicker.com/list/RrZjcc
You could alternatively in that build, choose a cheaper case, and get a nicer cooler on the GTX1080.
That is amazing, the price in my country are higher, but I'll definitely ask about that.
Did you mean 2x 8GB?
Get a Samsung 850 EVO, and at least 250GB. 128GB is not practical at all in 2016.
Oh right. Not sure what your options are really.
You can always refer to the budget build guide for parts reference and then translate them to the prices in Israel and pick the best parts you can get.
I would definitely ditch those rams you have in your listing for some DDR4-3000 ones, replace your transcend ssd with a Samsung 850 evo 250gb ssd, and ditch the motherboard for a Z170 chipset.
See if you can fit a H80i GT cooler instead of the H60, but that's really up to you.
