Nemanja Tesic
So I have GA-EX58-UD5 and I am planing on buying new ASUS RX 480 Graphics card , so can any one tell me is it compatible with this motherboard ?
I think I have 750W oneYes, it will work with your motherboard. Do you have a good enough power supply to run it though?
Its chieftecWhat is the model number? Wattage means nothing compared to brand name. You can buy a cheap 750 watt psu that is garbage, its actual wattage output will be less than 500 watts.
Its chieftec
Chieftec cft-750-14csDo you have specific model number handy? Should be okay but just wanting to verify actual model number.
Ok thanks allotThats a decent unit, should be fine.
