Xbox 360 to projector
Luke Benson
I've recently bought an elephas projector, but I'm having trouble connecting my xbox 360 to it.
What I've done/tried:
I switched on the xbox through the TV to confirm that it was set to SD (it was).
I've tried using different wires that I've had for various TVs in the past.
I've tried each input setting on the projector and each setting comes back with 'no signal'.
I couldn't attach the images of the wires I have.
I hope somebody can help! I've connected hdmi ready devices to the projector successfully, but I've had no luck with this device (without HDMI)
Luke
1. What specific projector did you buy?
2. Why don't you just connect it via HDMI?
It is Elephas, which I mentioned in the comment and the xbox 360 doesn't have a hdmi port
Every Xbox 360 v2.0 has a HDMI port. it looks like this:
images
if you have a v1.0 like I think you're referencing (SUPER old :P) you're out of luck with HDMI and a new cable might be something to try. Thing should be tossed out a window anyways hehe
