What cpu should i buy??
v@p3n@t1on
I currently have a Intel(R) Core(TM) i5-2500 CPU @ 3.30 GHz, 16 GB ram, geforce gtx 1060 6gb computer and i think i need to buy a new cpu . I would prefer to buy one for maximum 150 euro but what do you guys recommend??
That CPU is over 5 years old now and the socket it uses is pretty much dead now.
Unless you find a use i5/i7 on the 1155 socket, your looking at a full platform update (Motherboard, CPU, RAM)
I'd probably give it a shot on an overclock first, otherwise you'd be looking at either a used 3770k or a CPU/MB/RAM upgrade to something like 1151.
Most of those didn't have too many issues at 4.4-4.6 GHz, what kind of cooler do you have?
non-k though
I have no idea actually what kind of cooler i have, but you think i need a motherboard upgrade if i want to buy a new cpu?
Unless you find a socket 1155 used, you're gonna want to upgrade and get a decent mobo/cpu combo. I see a few 1155 sockets on some sites and the prices are astronomical cause they are past End of Life
Yep there have been a couple different sockets since your 1155 board came out. Even newer Haswell/Broadwell gear (4770k etc) is end of life and 1150 socket has been outdated.
The new platform is Skylake on 1151 and uses DDR4 RAM, so it'd be more of a holistic platform upgrade.
Ok, thanks for the help guys.
My socket 1150 cpu is from Q2 14' and its pretty much obsolete now
My socket 1150 cpu is from Q2 14' and its pretty much obsolete now.
Depends on what you use it for,i have two Desktops with Sandybridge motherboard Intel 5 2400 with 1155 socket and they do all i need 100% no need for fancy PC with modern mother boards and modern CpU, that cost much money,for me that i hate games i'm pretty much satisfied and don't need any other higher as long these ones works,and i have chance to repair them which i doubt with new modern tech PCs
..Depends on what you use it for,i have two Desktops with Sandybridge motherboard Intel 5 2400 with 1155 socket and they do all i need 100% no need for fancy PC with modern mother boards and modern CpU, that cost much money,for me that i hate games i'm pretty much satisfied and don't need any other higher as long these ones works,and i have chance to repair them which i doubt with new modern tech PCs
Please go on, this is valueble information...Zzzzzzzzzzzzzzzzzzzzzzzzz
