On further investigation, I have done an analysis and found this
Crash dump directory: C:\WINDOWS\Minidump
Crash dumps are enabled on your computer.
On Thu 22/09/2016 07:18:09 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\092216-20953-01.dmp
This was probably caused by the following module:
ntoskrnl.exe (nt+0x6BA3F7)
Bugcheck code: 0x124 (0x0, 0xFFFFD1800A9438F8, 0x0, 0x0)
Error:
WHEA_UNCORRECTABLE_ERROR
file path: C:\WINDOWS\system32\ntoskrnl.exe
product:
Microsoft® Windows® Operating System
company:
Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that a fatal hardware error has occurred. This bug check uses the error data that is provided by the Windows Hardware Error Architecture (WHEA).
This is likely to be caused by a hardware problem problem. This problem might also be caused because of overheating (thermal issue).
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Tue 20/09/2016 13:13:11 GMT your computer crashed
crash dump file: C:\WINDOWS\Minidump\092016-39750-01.dmp
Bugcheck code: 0x124 (0x0, 0xFFFF8282B5D218F8, 0x0, 0x0)
Error:
product:
company:
