Paint CD?
tremmor
Well-Known Member
just buy a cd label and print on it with the printer. That could be risky and not a good idea.
johnb35
Administrator
??? I am trying to find out if I can spray paint over the label of a CD without harming the readability...
I meant the purpose of using the spray paint. Technically you can't use certain types of permanent parkers on cd's.
Geoff
I would say no, primarily because the spray paint will spill over the edge of the CD and onto the readable surface. Also, depending on how thick the paint is applied, it could damage slot-load optical drives.
The VCR King
Well-Known Member
Go ahead and make fun of me... I tried this same thing myself a few years ago out of pure boredom. Long story short I ended up having to get a new stereo after I tried playing it.
Intel_man
Why don't you just print those cd label paper and stick it on top of the cd.
