fast router
tremmor
Well-Known Member
Daughters home. Big. 4500 sq ft. buying a fast router wireless and fast connection with cat 5 or 6.
Reaching into the house with wireless mostly and wants the speed. Whats the best.
thanks
voyagerfan99
ASUS RT-AC68U and then probably an access point plugged in somewhere to extend wireless network.
beers
Moderator
What kind of budget?
Half tempted to suggest an edgerouter and a couple ubnt AC access points.
tremmor
Well-Known Member
No more than $200. I think Voyagerfan was also talking about a repeater if needed.
Just don't want to spend anymore than i need to. Something from BestBuy would be great if they have it.
tremmor
Well-Known Member
So is his suggestion good beers? dont know which way to go.
Ready to get it today if i can. Or is there another suggestion.
beers
Moderator
You can give it a shot, it's a decent router, voyager is also a professional network engineer so knows what he's talking about.
4500 sq ft can be challenging if you have a lot of vertical space to cover (ie, three floors or similar). Most antennas have a much farther horizonal plane of coverage than vertical. You may need an additional access point on another floor in that case, also depends on what the house is built out of.
tremmor
Well-Known Member
Just the router voyagerfan mentioned. that might work fine.
Curious why not the wireless repeater/extender if needed. confused about it if needed.
Or is it slower.
Thanks Geoff
voyagerfan99
Or is it slower.
Thanks Geoff
Because you're saying repeater when. I'm saying access point. They are two completely different devices.
An access point takes the original network signal and transmits the same signal at full strength.
With a repeater it takes your wireless signal and retransmit it but it is a weaker network connection.
tremmor
Well-Known Member
Ok thanks............just trying to sort it out a bit.
Just not familiar with all the computer terminology.
thank you....
Okedokey
Well-Known Member
I was asking you what you thought of power line. Keep your ego under control mate, you're pathetic.
Geoff
You said:
"Powerline voy?"
If you really meant what you just stated, you should have asked a proper question. Such as "Voyager, what do you think about him using powerline adapters instead?"
Also, powerline adapters are a poor choice.
