Yes, I expanded before entering a command. Hell I expanded before entering a username and password.Worked fine for me with Putty and Windows 10. You expanded the window before running the command, right? It won't expand after you run it and then resize the window.
What version of Putty are you on? 0.67?Yes, I expanded before entering a command. Hell I expanded before entering a username and password.
Also, one other thing I noticed is that there isn't a scroll bar on the right to use to scroll up the page. Even if I'm only seeing half the content, I still can not scroll up.
Weird.... Please help....
