Building my 1st PC! How does this look?Tight budget!
johnb35
Administrator
Kind of disappointing!!!
Incompatible motherboard and processor for one. Poor quality psu and hard drive. What is your budget for this build? And I really wouldn't go AMD at this point.
Slitseed
I have about 550 USD, Thanks for helping me with this.
Calin
Well-Known Member
How about this? i3 + 1060 3GB. You can always throw in a cheap SSD later. This is assuming that it's a gaming PC.
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($109.99 @ SuperBiiz)
Motherboard: MSI H110M PRO-VD PLUS Micro ATX LGA1151 Motherboard ($46.98 @ Newegg)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory ($50.88 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.78 @ OutletPC)
Video Card: EVGA GeForce GTX 1060 3GB 3GB GAMING Video Card ($194.99 @ Newegg)
Case: Corsair 100R ATX Mid Tower Case ($49.99 @ B&H)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply ($49.99 @ B&H)
Total: $552.60
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2017-01-08 07:41 EST-0500
Slitseed
Total: $552.60
Yeah its for a gaming PC. The thing is i havent owned a PC since i was 18 and im 33 today so my knowing of whats good or bad quality is non existing sadly
johnb35
Administrator
Motherboard - https://www.inet.se/produkt/1900108/asus-h110m-a#specs - 699kr
ram - https://www.inet.se/produkt/6110163/corsair-8gb-2x4gb-ddr4-2133mhz-cl13-vengeance-lpx-rod#specs - 649kr
cpu - https://www.inet.se/produkt/5300004/intel-core-i3-6100-3-7-ghz-3mb#specs - 1349kr
psu - https://www.inet.se/produkt/6911368/corsair-cx430-430w#specs - 599kr
hdd - https://www.inet.se/produkt/4304280/wd-blue-1tb-7200rpm-64mb#specs - 549kr
video card - 1699kr
case - 499kr
total 6043kr = $664usd
Unfortunately, that is well over budget. And that is the lowest I would go. Basically you would need more money saved up.
Slitseed
video card - 1699kr
case - 499kr
Ok i will have to buy the components on a payment per month option instead. But thx guys i appreciate it
johnb35
Administrator
Also, what type of games are you planning on playing? The 1050ti may not be powerful enough depending on games played.
Slitseed
Im planing on playing civivilization and some shooters. Then hopefully get to upgrade it to play starcitizen when it comes out
Slitseed
While that is a viable option it will be much more expensive in the long term to start with entry level parts then move up to higher performance parts. Even if you resell the used parts you won't get what you paid for them.
Well im not gona pay 1000 USD at once for the PC so this will have to do.
