When I first got my case, I watched a completely bs guide about using it which commented that the middle pin intended for holding the motherboard in place is removable. Well, I went ahead to remove it and it just broke off. My motherboard has been mounted in my case without this middle pin for two years now. My question is this: is that middle pin just intended to help you thread the screws, or is it actually necessary to support the motherboard? Should I replace the entire case for that single piece? I'm considering adding a heavier heatsink, but I'm concerned that the mobo may not support the weight well without that middle pin. All 8 screws are properly threaded. It's just missing that middle support pin.
Here's a link to the case I have
https://www.amazon.com/Corsair-Carb...8&qid=1483994264&sr=1-3&keywords=corsair+case
