Yes, I dusted everything a few weeks ago when I got the newer parts.Well power supplies won't last forever, even top of the line models. I have a the corsair tx650 and its over 5 years old now. Also, are you sure your cpu fan isn't clogged with dust?
Dam mine isn't on there, thanks though. Mine is a H61 chip set and the model number is 2ADA according to CPU-Zthere is a utility from foxconn called fox one.dont know for sure if it supports your mb but it works with mine.
http://www.foxconnsupport.com/downl...us0000013&chipset=en-us0000154&keywords=&sort
It's a hit or a miss. Most half decent PSU's should last at least 5 years. If you don't like that some PSU's tend to crap out within 5 years... you may consider looking at purchasing a PSU with a 7-10 year warranty. Atleast that way, you know for a fact they're designed to atleast meet those warranty terms... well atleast they should. Or else the company will be losing lots of money and be firing a lot of incompetent people.It probably doesn't help that it's 5 years old either, that seems to be the life cycle of PSU's.
It's a possibility.I'm just hoping that this psu doesn't shit the bed before I get a new one and take out other components.
