Espozo
Hello! I've come here to ask how dumb of an idea it would be to create holes (long lines or circles placed in a honeycomb pattern, whatever's easier) in the bottom of my laptop to try and improve the airflow to keep it cooler. If this is okay, is there an optimal place to put them? I've heard that you're not supposed to have a vent directly under the fan, but I'd have thought this would be the best place for it.
Here's the laptop's back
And here's the motherboard underneath that. The DVD drive was taken out.
In case this information is needed, the CPU is an AMD A12-9700P RADEON R7 @ 2.5GHz. It's an APU, but oddly enough, those 3 screw holes are where it appears a GPU is supposed to be, and it's even labeled as such. I don't remember the computer model, but it's a 17" HP I got this December. System in Windows says the computer name is DESKTOP-76NCIU1.
