Is this build compatible?
What do you consider as "regular gaming" and what is your budget?? I would like to chime in but don't want to just spout things off without knowing what your overall intentions are for your system.
The performance on this build is perfect I just wanted to know if this is compatible and works well
I would recommend getting a bigger SSD drive though. You'll quickly run out of space on the 128gb.
I don't know much but doesn't the 2tb hdd make up for that?
Realistically you'd want your OS and most used applications on the SSD. Given the downward cost of SSD having a little more breathing room with 256GB or similar wouldn't be a bad idea, depending on how much crap you want to have on it.
Per Calin you can install stuff to the 2 TB HDD but it will be significantly slower.
