YourDigitalJester
Im currently in the process of testing Linux builds for my laptop, as well as my PC tower. Im going to do a semi-detailed write up of everything ive tried so far. Links will come shortly
Laptop Specs
Intel Pentium Dual/core T2330
2GB Ram
120GB HDD
VMware Settings (true amongst all tests below)
2GB Memory
1 Processor
2 cores
20GB Hard Disk (cant change this setting)
Network Adapter NAT
Usb Controller Present
Sound Card Auto Detect
Printer Present
Display Auto Detect
Ubuntu Builds-
Ubuntu 14.04- What was on my laptop, its slightly too intensive for my Acer Aspire 5715Z Laptop, its an amazing OS but i need something a bit lighter. Never tested CPU usage, ill throw it in my VM later on my laptops specs and see what comes up.
Ubuntu 15.10- What im looking to replace, its currently installed on my laptop and is an improvement over 14.04 due to optimizations but is a large file (i have almost filled my HDD with not much else installed). As with 14.04, i love the OS and i would run it any day on a better laptop, but i need something better.
Ubuntu 16.10- I LOVE this build of ubuntu on my PC, it gave me issues at first (well documented issue with the ubuntu sound card drivers and Xonar sound card, though fixed). The optimization of it is fantastic. On my specs (listed below Tails) i get 8.5% CPU usage running youtube, URC, The GEForce website (downloading proper graphics drivers for my PC, the default ones dont give this card its maximum power), and running VMware with two os's running (one of them is downloading itself to VMware too). Cant say enough good things about 16.04.
Tails- Ubuntu 14.10 with extra securities (everything runs through TOR, memory Cache is wiped every time you shut it off), as well as a lighter desktop to decrease CPU usage. I found it idleing to be a very good OS for low powered systems, but TOR is a very intensive browser that lagged horribly when constricted to the settings above. I might put it on my tower in all honesty, the securities are nice and my PC is quite built...
7.8 GB Ram
Intel® Xeon CPU E5506 @ 2.13GHz × 4
GeForce GTS 450 Performance Edition
Bodhi- Another Ubuntu 14.XX based build, made for light-weight needs and sounded perfect in theory! It did indeed use almost zero CPU, and ran smoothly. In all honesty i should use this or Lubnutu but its so dang ugly! The limited settings dont allow it to look pretty at all, and i refuse to work on an ugly OS. If you can get past the looks, or find it pretty then by all means use Bodhi, youll find it very quick (and fast) to use
Lubuntu- Not worth saying much about, its hardly different than Bodhi, i find it uglier. My opinons are the same as Bodhi.
KXStudio- A great OS for someone doing a lot of sound work, preloaded with the best free audio editors that ubuntu supports. Cpu usage in the VM stayed around 5% as with Zorin, but boots slower and seems to stutter under load. It also had a bug where it wouldnt properly shut down, i had to force it.
Zorin- After testing it thoughly on my virtual machine this is what was picked for my laptop! Both on the VM and on my laptop im averaging 5% cpu usage at idle, which for the specs of the laptop is good. This a truly amazing build of ubuntu and one i will forever reccomend. Ill update this if it shows any issues, but nothing seems wrong so far. Preloaded with chrome is always nice, even though ill be installing opera, Chrominium is a great browser.
			Laptop Specs
2GB Ram
120GB HDD
2GB Memory
1 Processor
2 cores
Network Adapter NAT
Printer Present
Display Auto Detect
Ubuntu Builds-
7.8 GB Ram
