Master password
David Williams
I keep all my passwords in keesafe Passwords safe. I have put in the master password but it says error
0x0000000E Invalid File Header. Does anyone have an answer?:(
Bit of a nuisance if it wont let you access your passwords. I never trust those programs. I always write mine down and NEVER have anything on my computer that is going to to be a massive problem if I lose a password. I do not believe that computers or the internet are anywhere secure enough to be doing stuff like internet banking etc and as for storing stuff in the "cloud" no way.
Sounds like it might be corrupted.
Usually you want to keep backups of the pw db
Why not? I don't see you breaking a modern cipher in any reasonable timeframe.
But you might not have to.
I just checked my banks website and it's running a bunch of vulnerable ciphers. I can just disable them in chrome, but what if I don't know that.
Switch banks, the backend implementation is likely horrific as well :p
That'd be more of a specific implementation issue. Was just going against the argument that 'computers aren't secure enough for banking' or similar, which sounded largely sensationalized.
