So I'm thinking of buying a new motherboard, RAM and CPU. I have Corsair's RM750 PSU and I've read that I need to check PSU - motherboard compatibility. The CPU I'm getting is DDR4 2133MHz, so I'm getting the same type of RAM and motherboard. The two motherboards I've mentioned are both DDR4 2133MHz (stock), just different sizes and I want to check whether or not my pc case can support the bigger one as well, since the one I currently have installed is Asus P8H61-M LE R2.0 (Micro ATX). My pc case is Corsair's Carbide Series SPEC-01 Mid Tower Gaming Case.
CPU: from i5-2500 to i5-7600K
RAM: from 2x4GB sticks to 2x8GB or 1x16GB, gotta research whether I should prefer one of the two
Motherboard: from P8H61-M LE R2.0 to H110M-K or Z170-HD3P
