Buzzing noise from TWO pc setup
^Seriously dude?
Obvious solution is to not have volume up on both machines simultaneously. It sounds like some sort of interference.
Hello, I have a two PC setup both PCs going into this mixer: https://tinyurl.com/j98bodr and I get this really annoying buzzing when I have both PCs volume on at one time. Anyway I could fix this? Thank you.
The noise you hear is motherboard signal interference. If you are using on board sound hardware that is the cause. Look into either high end pcie sound cards or motherboards with shielded audio dacs.
You sir, are a genius thank you very much I will be looking into this ASAP.
P.S. Sorry for the LATE LATE reply... thank you again
