Stuck power button
On some cases you just grab the bottom and yank. Others require you to push in tabs on each side before pulling front off, can't really tell with that case and instructions don't say either.
^This. Also, in future, keep your drinks, sugary and otherwise, a safe distance away from your electronics. You got lucky that the innards of your PC weren't soaked.
In addition to the others, I also tried to find a proper .pdf or video of disassembly on the case but no luck.. @johnb35 is right though, its either tab and pull off or clips, possibly a small screw or 2, but it should be very straight forward to remove...just gotta look and see whats attaching it... should be fairly obvious after inspecting.
I tried it your way and apparently that is how it comes off.
