Blue screen!
About week ago i was watching yt video and screen flickered and blue screen appeard with some text..
Today i was in middle of competitive csgo match and monitor flickered and blue screen appeard .
So any clues whats doing it?
That and blending with the issues you had with memory earlier in another slot, seems RAM related. Did you manually set the speed/timings/voltage that your sticks are rated for from within BIOS?
so i set everything to maximum the othor day maybe this is because of it?
Probably, you want to run everything at stock speed when troubleshooting stability issues. Overclocking in the exploratory phase adds a lot of instability.
Usually if the card is out of spec it will indicate a driver crash instead of BSOD. I'd still investigate the RAM side based on the slot related issues earlier :P
