PCI compatibility
Xander95
I am looking to hopefully install multiple graphic cards and my current build has the following slot compatibilities.
1 PCIe Express 3.0 x16
1 PCIe 2.0 x16
2 PCIe 2.0 x1
3 PCI
The graphics cards I want to run uses 3.0 so is it possible to install a PCIe Express 3.0 card in a 2.0 slot? I really don't wanna build a whole new computer yet.
What are the rest of your specs? Which specific cards are you looking to use?
PCIE 2.0 16x has the same bandwidth as a PCIE 3.0 8x slot and the card is backwards compatible with the previous standard.
It depends on the following circumstances...
  • What motherboard chipset are you running
  • what multi-gpu setup are you trying to achieve (SLi/CF/other)
  • What PSU are you running
  • What are you trying to achieve in terms of performance.
There's a few other questions to ask, but those are the four I'd ask straight off the bat.
Well there's 2 problems here. Your mobo doesn't support SLi and GTX 1050 Ti doesn't support SLi.
What's the rest of your specs of your computer and what kind of a budget are you looking at to improving your computer?
I am just making gradual upgrades. I am on a tight budget as of right now. I am running a 4.3 GHz A10 processor, 8gb of RAM, a Radeon R7 integrated graphics (hence why I am getting a graphics card), and Windows 7. That is all the info I have. I am just trying to upgrade it so I can play some upcoming betas.
Is that one stick of RAM or two?
I wouldn't run dual gpu on fm2. Plus if you don't even own one of the cards already it's always a better buy to get the single faster card.
Would you mind explaining to me why ya wouldn't run dual gpu on fm2? I am still learning.
The CPU will be a bottleneck to a multi-gpu setup in performance to the point where it's not worth the cost of running a dual gpu setup. You'd be better off spending money elsewhere to gain some performance.
So I should just run a single graphics card? Cuz I'm fine with that. I could disable the integrated graphics and switch over to the graphics card.
You'd have to go at least 1070 for SLI, that's pretty expensive and even if you bought them the FM2 platform is limited to 4-core/2-module processors, which aren't sufficient for most modern games. You'd still get low performance and stuttering in a lot of situations based on not having enough available CPU resources.
When you install the video card and hook it up your motherboard will automatically turn off the integrated graphics and switch to the video card, you can't run both at the same time. If it doesn't automatically change it you have to go into the bios and change it.
Give it a try on the 3330 if you ever need additional monitor connections for 2d productivity :D
