Computer not powering on
Xander95
Okay I know I have made MANY posts on here but this takes the cake. I got everything up and running alright and now it's not powering on. All I did was try to install fans and it was powering on for a while but now it's completely dead. I don't know if my power supply just died on me or not. I need help here.
There is usually 1 light somewhere that designates its getting power. Check to make sure both 4/8 pin cpu and 24 pin main connectors are securely attached. You may have dislodged something while replacing fans.
I had it running a few times after I installed all the fans. I restarted it a few times to make sure and it kept powering on. And then
Thats the chassis intrusion header, you have most likely screwed up the motherboard. Why would you connect anything there without reading up on it? What LED power connector?
There's LEDs on my side panel fan that I was trying to get to light up and I thought because it was a 2 pin connector that it would work. I thought wrong.
I thought wrong.
Yes you did, unfortunately. However, try resetting cmos. Unplug power supply, remove cmos battery from motherbaord, press and hold power button on case for 10 seconds then wait 10 minutes. Then reinsert battery, reconnect power and try turning it on.
I'll try that but it's gonna be a while. I already removed the power supply. Like an idiot.
So I just installed the new power supply and it's still not powering on. So I think the old power supply took the board with it. I'm ****ed.
