Unknown startup software slowing down PC
If you can find it in your own country that would be best.
Thank you.
About the malware stuff, now I've got some other problems. For example, I can't view images with windows photo viewer since when I click on any jpg file I get an error which says can't start photo viewer. Or I can't use my start menu. It doesn't show up no matter how many times I click on it or press the start menu button on the keyboard.
Did you uninstall malwarebytes yet? Between your malware issue and low memory this is what is causing your issues.
Is this a pirated OS? I noticed its windows 10 enterprise and that usually means its pirated with someone with only 2gb of memory, also saw that you have a torrent program installed. If you have any other pirated software installed, I suggest you get rid of it or better yet, install a new copy of windows with a good key.
