Samuel Georgiou-Brunt
Hey computer fans, I have a build for you to verify!
I am in the U.K (£, GBP)
£1 = $1.3 US
I am currently getting my build for my life here at my mums sorted out and I am working on a tight budget (£500 max, as cheap as possible). I have worked out a great (I think) build, however, as it is my first time and I'm not exactly the worlds best expert, I may have tripped up. I would like to know if:
A) all parts are compatible (I think they are)
B) all parts are optimal / best for the job
C) if I have found the best prices for all parts
D) are all cables there (such as PSU or FanHub)
E) are there any better solutions at the same price
F) would thermals be an issue (CPU StuckCooler in use)
I have looked around for a while for best prices, but there still may be some better ones out there. Also, in terms of graphics card, I know the RX460 (AMD) is more budget friendly but I have watched some videos and the 1050 is worth the little extra in my opinion. I'm only looking to play things like CS:GO, Rocket League and maybe a bit of Planet Coaster so no spectacular requirements are an issue. I have all peripherals so I do not need any more. My monitor is 1080p.
So, for the bit you've all been waiting for: the build:
(Most were free shipping, so don't worry about that)
TT Versa H15 M-ATX Case-------------------£34.98
GIGABYTE GA-H110-DDR3-----------------£51.57(IncDelvery)
Core i3-7100-------------------------------------£99.90
350W VS Series Corsair ATX PSU---------£32.97
GTX 1050 GIGABYTE OC 2GB-------------£108.47
QUMOX 8GB DDR3 1600 RAM-------------£46.00
TP-LINK PCIe Wireless Card----------------£11.99
Toshiba P300 1TB 3.5" HDD----------------£37.97
Mr HIGHTECH Win10 Home----------------£9.99
GameMax Galeforce Fans x4---------------£15.96
Phanteks ph-pwhub Fan hub----------------£17.99
______________________________________Total
14 Items-------------------------------------£467.79
The places I found them from are below in identicle order:
http://www.ebuyer.com/711134-therma...e-window-usb3-black-interior-ca-1d4-00s1wn-00
http://www.pcupgrade.co.uk/productdetails.asp?productid=36178&categoryid=728
https://www.amazon.co.uk/Intel-Core-I3-7100-3-90-GHz/dp/B01NCESRJX
https://www.amazon.co.uk/Corsair-CP-9020095-UK-VS350-Power-Supply/dp/B009X1KGXS
http://www.ebuyer.com/761963-gigabyte-nvidia-geforce-gtx-1050-oc-2gb-gv-n1050oc-2gd
https://www.amazon.co.uk/QUMOX-PC3-12800-Desktop-Memory-240pin/dp/B00TGPSHI2/ref=sr_1_46?s=computers&ie=UTF8&qid=1502139069&sr=1-46&keywords=1600+8gb+DDR3
http://www.currys.co.uk/gbuk/comput...-wn881nd-pcie-wireless-card-10119361-pdt.html
http://www.ebuyer.com/726222-toshiba-p300-1tb-3-5-sata-high-performance-hard-drive-oem-hdwd110uzsva
https://www.mrhightech.net/operating-systems/3571-microsoft-windows-10-home-0885370909784.html
https://www.amazon.co.uk/Computer-Silent-120mm-Galeforce-iCHOOSE/dp/B01FXJBH72?th=1
https://www.amazon.co.uk/Phanteks-PH-PWHUB_01-system-fan-hub/dp/B00M0R05WE
It may not be the most interesting build or forum post, but feel free to brag about your builds and give me any criticism, constructive or not. Im ready for your potato and toaster comments. Just note, I have a not-so-budget computer at my dads
Fire Away!
£1 = $1.3 US
