You really shouldn't be trying to use 2.4. If your devices support it, 5GHz is much better.I am looking for a $120 or less that has good 2.4ghz speed at 60ft to 80ft with removable antennas not a Asus had one and had problems with it what do you recommend??
I have that, but it's fairly expensive for most people and unless you really need that gigabit wireless connection, cheaper alternatives can be purchased instead.Asus RT-AC88U mate swears by it
Oh snap. I did not even notice. XDDid you ever decide, OP?
It's been a few months.
That doesn't define parameters for which of the two (or an alternative) is actually best.Only use best
And what do you think is best?Only use best
