OmniDyne
Hello!
I have a few questions about the memory in my system. I built this computer in June 2017. I've had no issues at all; no crashes, no hangs. It runs well. I'm curious about the DRAM frequency and timings profile the motherboard has automatically set the memory to.
CPU-Z shows DRAM frequency and timings slightly higher than what G.SKILL recommends. The BIOS (non-UEFI) mimics what CPU-Z reported, so CPU-Z seems to be accurate, and reports settings at JEDEC #6.
G.SKILL recommends CL9-9-9-24, which according to CPU-Z, would be XMP-1600. I didn't see an XMP profile option in the BIOS, and the memory profile is set to Auto.
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3
Motherboard: GA-78LMT-USB3 (rev. 6.0)
All BIOS settings are stock, Auto. No overclock.
CPU-Z reports DRAM frequency at 1607MHz. Is this an issue?
Is a slightly higher latency something to be concerned about at all?
