Replacement for Arock Z68 3 pro
Pausop
Hi.
My above mentioned motherboard is not working anymore. The only identical one I can find costs 130€ and is second hand.
I am not willing to pay that for a second hand old motherboard.
Which motherboard could I get which would have the same functions, ports etc. And would work with all my other components.
I am not really willing to pay more than 50€ as I will probably get a new system in the next year. I just need to urgently access my computer.
Any recommendations?
Thsnk you.
Paula
Darren
Moderator
Just need to match Chipset, usually features are pretty standardized across chipsets. So anything that's a Z68 should do the trick, just make sure it has the correct number of ports and the like for your needs.
johnb35
Administrator
Can you give us some ideas on where you can get it from? With you being in a different country its hard.
Pausop
We have online shops. Of course amazon.de. my socket also needs to be 1155 doesn't it? Or could I use a different socket.
I'm in Austria by the way.
Paula
Pausop
Most likely gonna have to go to ebay. What about this one?
https://www.ebay.de/itm/ASRock-Z68-...251555&hash=item362ebfffd9:g:zDMAAOSwigxakqUr
Searching for the good replacement could take a while. I'm seeing a lot ships from china too.
Yeah. I've never used eBay before. Not sure I really trust it.
That particular one is second hand and costs 5€ to send which makes it almost 100€ for a second hand motherboard. Not really digging that.
Do I have to have z68 and socket 1155 both?
Thanks for the effort.
Paula
johnb35
Administrator
z68 is the chipset of your current motherboard. 1155 is the socket name that it has. Some Z77 chipset boards will support your cpu. Any place other then ebay is gonna be charging an arm and a leg with it being so old I think.
beers
Moderator
Other chipsets like Z87 support different CPUs. You can fit 1155 CPUs in 6 and 7 series boards (P67, Z77 etc) but otherwise yes it would require another CPU. If you roll with new 1151 platforms also you would have to buy DDR4, which is still really inflated in price.
Pausop
Ok
OK. Thanks. I'll have to think about what I want to do. Would a bundle be anything?
Paula
johnb35
Administrator
Motherboard, cpu, ram bundles usually save you up to 50 bucks or so compared to buying them separately. Just all depends.
johnb35
Administrator
You'll be going from a quad core to a dual core but if it does for what you'll be using it for then why not?
Pausop
Actually that is the problem. I don't find a motherboard with the same amounts of connectors in any of the areas which doesn't work for me as mine are mostly in use.
Stuck in a bit of a whole here.
