S smart zulu New Member Apr 14, 2018 #1 Hello, I am having a challenge to ascertain the problem with my dell lcd , Based on the photo attached , can anyone help if it is the lcd or the cable or just something to do with the graphics? Your time and help will be highly appreciated Attachments IMG_20180414_145708.jpg 640.4 KB · Views: 8
johnb35 Administrator Staff member Apr 14, 2018 #2 Try updating the video drivers first. Other then that its probably the screen itself or loose video cable.
beers Moderator Staff member Apr 15, 2018 #3 I'd suspect the screen itself with that kind of pattern but you might as well go through the other tshoot steps to rule them out.
S smart zulu New Member Apr 16, 2018 #4 I have tried updating the graphic drivers using drive easy and windows update but i still get error code 43.. could the problem be with the graphics ?
beers Moderator Staff member Apr 16, 2018 #5 smart zulu said: could the problem be with the graphics ? Click to expand... You can isolate the GPU from the laptop screen by connecting an external monitor
S smart zulu New Member Apr 16, 2018 #6 I tried projecting but it says unable to because it cannot detect another monitor
S smart zulu New Member Apr 16, 2018 #7 beers said: You can isolate the GPU from the laptop screen by connecting an external monitor Click to expand... I tried that it says unable to detect monitor
